First off the car was running great until after going wot it started running rough at idle. Ended up being the iac gasket partley blew apart creating a vacuum leak. So I put a new gasket in and while tighting the iac it broke. So I put in a new one set it according to the web site and I have the same problem again, running rough at idle and starting off from a stop. Still runs great after 1500 rpm's on up. Scanmaster shows 800 =/- 25 rpm's and 23- 40 iac when engine is warm. This is the only thing I have done to it. TPS is at 44.
List of mods
231 c.i. Buick V6
Ported & Polished Heads
Champion Ported Intake
Ported Throttle Body &
Upper Plenum
Poston Headers
009 injectors ( 42.5 lbs per hour )
TE44 Turbo
Kenne Bell Front Mount Intercooler
210-205 cam
Hi Volume Oil Pump
3 inch Down Pipe
Flowmaster Exhaust
LT1 MAF with translater
SMC Alcohol Injection
I am not sure what chip is in the car. I have ordered an extended chip just in case it isn't one. This setup was on the car when I bought it. The motor was rebuilt 1200 miles ago and have not had any problems till this happened.
