I figure you are actually a good guy.
I figure we're,pretty much,all good guys till a girl moves in with us.
Many owners have posted that installing a DW pump did NOT require them to modify the fuel return line, so you are way off base there.
Yes they did.
You reported that Richard Clark found that fuel pressure was a potential problem.
You explained the details of a test that you were a part of in witch the fuel return line was Modified.
Three people in this thread,including Eric Marshal,noted the same problem.
That's a total of five people in this thread,including you,who acknowledge this problem.
Six,including me.I assume we are all off base.
When you made the statement that a DW pump "WILL heat the fuel more", I did not believe it, but decided to get a REAL expert to provide some data which is now shown as actual test results that it does NOT heat the fuel more, but the Walbro does?
So,you're saying that a fuel pump that flows more fuel to a hot motor (and therefor returns more fuel back to the tank) doesn't heat the fuel in the tank more than a pump that moves less fuel to a hot environment (and therefor returns less fuel to the tank)
You're,also saying that a fuel pump that requires more amperage,to do more work,doesn't heat the fuel more.
And,also your saying that the pump that flows less and draws less amperage,actually heats the fuel more than the higher flowing,higher power drawing pump.
People are going to get the impression that you will defend this thing until,well you know.
So again, please do not erode the credibility of our board by stating your opinions as facts!
Please! Please! Quote any of my statements ,in this thread,pertaining to fuel pressure or heat that aren't factual.
Please refer to post 127.
