Last summer I put a 4000 rpm stall converter in my car, but did not drive it any. Last Monday night I finally took it out for the first time in a year. But when I was cruising through the gears it did not feel right when it shifted into high gear. It almost felt like the transmission was low in fluid or the shifter cable was not adjusted properly. Almost like it didn’t fully go into high gear. I am going to check the cable soon just to make sure everything is right. It was very lazy going into gear. My question is does the RPMs play a factor in the way the transmission will shift? I was shifting it into high at approx. 2500 RPM. So theoretically the converter is not “locking up” since it is not in the neighborhood of 4000. Will this make the transmission shift into high slower because the converter is not in its efficiency range?
