Why do so many members complain about the high cost of ownership for a turbo regal? If you are starting with a relatively clean example regular maintenance parts are cheap. If you are staying relatively stock the costs should not skyrocket. Yes there are shortcomings that need to be addressed, ie braking and suspension, but there are plenty of brake upgrade options that wont break the bank if you know where to look. Suspension, well that wont be too bad. The stock bottom end of the engine is stout enough for mild performance upgrades, kenne bell had a stage 1 block in the 7s 20 years ago. The trans is a weak point but a th350 swap is doable, and 200r4 are available in every junkyard nationwide. Try maintaining a stock bmw or vw. Parts expense is much higher. Granted if you need alot of out of production body panels or interior parts it may get pricey, but the same goes for any classic. As for hot air performance being much more expensive than an ic model I dont see it in this day and age. Alky injection and em options like megasquirt are very affordable. Do your research and plan it right and you should have a very capable and reliable dual purpose vehicle for minimal cost.
