headgasket suggestions
WE287GN
looking for suggestions ,so far i am running the felpro 1000's
i am having the loosing coolant,wet tailpipes ,water in valve covers but not the oil , good compresion bad leak down #'s blues
also tried coolant die with no results, so still not sure i have gasket problems so guess i gotta rip it apart.
85 turbo riv block with 8445's
i have had a few suggest the stock 85 gaskets,wich doesnt sound like a bad idea, i intend on keeping the arps and using the arp sealer,
lloking for a few more suggestions on the situation
thanks
Chris Pacheco
WE287GN
Well, if you're having problems getting compostion gaskets to seal, good luck getting 84/5 steel shim gaskets to seal...
I'd go with the stock GM 86/7 head gaskets or the Fel-Pro replacements, I think they're the 9441's or something...
Hi, I had thaught about the 87 stockers, but it was suggested to me by someone that i should go with 85's because of deck height and gasket thickness between the years
would the 87's hurt me, i forgot the mechanics behind it
thanks
Chris Pacheco
if its a 85 block then there is no question ...to ask you wont beat a single steel shim.
i had compression leaking problems with stacked steels on my 87 motor but on my 85 with single steel i couldnt make then leak and believe me i tried..:D
i pulled my motor down for inspection after my turbo failures and have now gone to a single steel on my 87 motor.
with the 85 block you are hurting your performance by going with a thick gasket they were designed for single steels
DOH!!!! Assumed 86/7 block...Maybe it's because of your screen name...
85 Riv motor didn't register for some reason...
Stock 84/5 steel shims would be fine...Just make sure the heads and deck surface are absolutely flat and not warped, and you should be fine...The only thing that running the composition 86/7 gaskets would do is they would lower your compression maybe half a point...heheh, just turn the boost up a little more... :D
jim,red,mike, thanks for the response...after mikes post and the fact that i've heard the extra bolts holes on the 1000's may contribute to a problem,i have decided to not go with those.
i will go with the stock steels ..
the only thing i'm stumped on were my test results, i got 160-165 on comp test, but high % on leak down anywhere from 40-55
no leaks between cylinders, no bubbles in radiator with air in the cyl.just loosing water and guees its steeming to collect up in the valve covers???? must be a very small leak???
just suprised the car runs as good if my leakdown is that high
could this be my low boost issue also? i had swapped my boost actautor from my other car and i know it wasnt set this low, i'm gettign max 10lbs boost, but i do have a drivers side header leak,
just blabbing here,
thanks
Chris Pacheco
