Hanny87
- Jun 16, 2014
I just installed my 80lb injector/chip combo from turbo tweak and am having some problems. I'm not sure if this is an e85 problem, or something else in the motor. I changed out my old 60 lb injectors and 93 octane chip for the 80's and e85 chip. Car started right up and seemed to idle fine. I let it get up to temp before I took it for a drive. Everything was going good for the first few miles... I was on the highway and laid into the throttle a bit to pass a car. Was maybe only half throttle and about 18lbs of boost when I heard a pop! Immediately let off, and then about 30 seconds later it started sputtering and lost all power. Got it back home and pulled the plugs, because it was running extremely rich. Plugs were black! Changed out the plugs, and still doing it. Changed out the crank sensor with a spare I had, checked the cam sensor to make sure it was still lined up. Everything seems to be good. It's not throwing any codes. Antifreeze and oil look fine. No blow by through the breathers, no leaks anywhere I can find. Still running extremely rich at idle. I let it warm up to temp after checking everything, and it idled a little rough. Temp reached 160, and it started idling really rough and then died. Also, weird thing was when I started it coolant temp was 100, and the fan came on high speed and stayed on. I haven't officially done a compression test, but when turning the motor over by hand it still seemed to have good compression. I'll check it for sure tomorrow night. Not sure what else to check... already sold my old chip and injectors, so I can't immediately switch back. Anyone have any suggestions or run into this before?
