it can fall off on hard acceleration but not because of gforce affecting fuel flow through the line , the pump will pull fuel even from the trunk . it can fall off on hard launch because all the liguid in the stock GN reservior gets forced to the rear of the tank and the outlet being at the front goes dry and theres only so much liquid in the feed line and once its gone pressure will drop , a fix would be install an upright reserve bladder (like a small 16 oz overflow bottle) inline beside the pump to carry you for a few seconds until the fluid settles back, that would also allow reserve to cover a full pass even if the main reservior were at empty
my fix was to position the tank with outlet at the rear since i usually run the tank past half after a couple runs
with the outlet at the rear like a sump fuel tank i can make a run with only having alky at just about where the low sensor is active at rest.
otherwise just keep it topped up , that seemed to work on logs where running it even a couple inches low would show signs of a pressure drop near top of first , but this was track conditions coming off a tbrake
