First of all I am new here so please be patient with me if I am not knowledgeable about some aspects of this build and your help and input is greatly appreciated to get this thing done right!
I'm doing a full rebuild on this motor and need some help on picking out some parts. I already bought the turbo which is a turbonetics 67 mm ball bearing made for the grand national which doing some research (correct me if I am wrong) will produce about 650hp with a decent built motor, now you have an idea of the hp I'm trying to achieve.
Here are the parts I need help with assuming that the stock parts will be up to par if we use them. If there is a better recipe or avenue please let me know.
1. Rods - stock or upgrade?
2. Pistons - forged alum of course
3. Crank - stock or upgrade?
4. Cam - flat or roller?
5. Heads - stock heads but getting them redone
6. Plenum - 70+ tb
7. Headers - stock?
8. Gridle - do I need it?
9. Plenum spacer - do I need it?
10. Timing chain - double roller
11. Harmonic balancer - stock?
12. Roller lifters - do I need them?
13. Fuel rail - ?
14. Intake manifold - port?
15 . Chip/injectors - turbo tweak
16. Alky - good idea?
17. Radiator - 3 row dual electric fans
18. Down pipe - 3" enough?
19. Blow off valve - ?
20. Rjc deep oil pan - ?
Thank you for taking the time to help me and if I am missing anything please let me know!
6. Plenum - 70+ tb
7. Headers - stock?
13. Fuel rail - ?
