3 inch downpipe, has a wierd triangle flange that i havent seen before (came on the car when i bought it). Has two minor dents. No hole for a puck. Comes with cat and test pipe with the same flange. The rear flange is the normal rectangler one. $80 Plus Shipping
Walbro 255 Pump with sending unit (looks stock). Worked perfect on my car with 60lb injectors. Just went bigger. $50 Plus Shipping
Oriellys MAF sensor, about 10 miles. Tested it out to 255 grams at WOT. Its is actually a good reman. Figured someone could use it instead of trying 10 units out to find a good one. I just went with a translator and LS1 MAF. $25???
Brand new 35mm Turbonetics Evolution external WG. Comes with all the fittings and springs. Never installed just opened. $190
