Fuel pump is to big.Car seems to be running rich on start up then few minutes seems ok. I have fuel pressure set at 43psi line off,but when i put line back on drops to 41psi you can adjust the regulator but i will not not go any lower. is the return line plugged up?
I have a new 255[/QUO
Gauge seems to work right i can turn it up to 50 turn it back down it stops at 41psi will not not go any lowerI have a new 255
See above, I have a 255 and had a stock appearing regulator I had to swap out for the Kirban one. I have my hotwire off at idle also as it bumps pressure 2#. Every car is different. Free to check the return line for damage.Fuel pump is to big.
Return line is too small.
Return line is kinked or damaged in some way.
Regulator is junk.
Gauge is wrong / inaccurate.
Regulator is junk.
Just trying to see if the blm would raise.IMOP the fuel pressure isn't the issue. Also why would you want fuel pressure lower than 41 line on?
Ok?With car running vac line off set at 43psi hook vac back up maybe drops one psi.
I thought it should drop to around 38 psi. Maybe the reason its running rick.Ok?
