Thanks Rich,
If I understand you correctly, this system will always use the same preset values from the lookup tables and continually correct for them if needed by changing the duty cycle of the mixture control solenoid, it won't rewrite the tables.
I really had no idea on what it was doing, that will help with tuning to resolve drivability issues.
I am waiting on a monitor 2000 I won from ebay, so I can start looking at things. WOT tuning is still the same, monitor knock, timing, boost and O2 (maybe EGT when I put it in), then tweak boost, timing and swap needles as necessary. I guess there's not much reason to monitor voltage as with the 87's.
I run a translator plus in my 87GN, sure would be nice to have that tunability in the 82.
I remember back in the day (1995) Snap On had a little book you could look up the PROM ID and see if it had been superceded due to corrections. Sound familiar? I would be curios to check mine.
