Going to bigger injectors?
Nice power-let me know if you want to sell the 160s- that would be enough power for my street car!
The dyno sheet says all this happened at under 4300 rpm Was this on an engine dyno? If not, what convertor do you have to hold that much hp and boost at such a low rpm?
What fuel pump and size fuels are you running?
thats what i was wondering....max power at 4242rpm?
Cal, Maybe it was the dyno rpm pick up
I was thinking the same thing Tom. You know how much it skewed your data. Although, the 80mph sounds about right for 4200rpm in 3rd gear.
Would that not change the hp#?
do what you need. May be a handful to get tamed for street driving???
In the "fwiw" dept: I just finished some 550's and 160's for a local shop....[These are staged, w/ the 550's on static when the 160's hit 50% dc.]
He is using strait meth @ 40# boost, 70psi fuel psi....
Is reporting a duty cycle at 95%
He's stepping up to 220/550 combo...
how do you know what rpm the motor likes and or peak power?
Kinda a ****ty way to do it, how do you know what rpm the motor likes and or peak power?
