Thanks guys for chimming in......when I did the clone I also used the interior wiring harness so I could use the 82 TRSC dash and ECM. I also used the 82 Distributor and 82 knock sensor. I pretty much converted everything to 82 so it would be plug and play since I had the whole donor car. It worked relatively well, but the wiring harness connectors forced me to use the 82 steering column, heater controls and wiper motor, so I wouldn't have to modify anything. The one thing I missed was the ESC Module which I didn't realize until it was throwing the ESC Code after I got it running. I did pull a ESC Module from a 82 NA Regal and put it in and then the code never returned. From what I'm gathering, it doesn't matter if it's NA or Turbo as long as the components match which I think mine do......I will verify them as soon as I get the car back in the garage.
I did read the Before Black website before I posted, but it wasn't specific about using a NA ESC Module in a Turbo application, so I thought I would ask. I will have to perform the Knock Diagnostics tests to ensure the ESC system is functioning correctly. I'm also going to verify the MAP sensors just to be sure they are operating within the proper range.
I also read the sticky post on "Carb Info for the Turbo Design".....it was a good read and I will have to check a few things out based on what I read there.
I have developed a decent laundry list of things to check and verify, so it will keep me busy for a while.
Can someone point me to a place where I can read up on the computer controlled carb......I want to understand how each aspect of it is supposed to operate so I can check everything out.
Also, since I put my 82 components on the 84 NA long block, do I have to do any rejetting since the 84 heads flow more air?
I appreciate all of your help......it's been 3 years since I put the car together....and honestly I haven't touched it since and I have forgotten more than I realized.....but it's all coming back to me.....slowly!
