scanmaster readings are AF 04, BAT 13, BL 120-130 MOVES SLOWLY, CLT 205, ATS 109, RPM 825-850, TPS 44, IAC SLOWLY GOES DOWN AS IT WARMS UP I WAITED TILL IT GOT TO 10 BUT HANGS AROUND AT 38 TO 22 FOR A GOOD WHILE
I KNOW THE IAC SEEMS HIGH BUT AFTER I BLIP THE THROTTLE A COUPLE OF TIMES THE IAC STARTS TO GO DOWN
COULD MY BOOST CONTROLLER HAVE ANYTHING TO DO WITH THIS I BOUGHT AN RJC BOOST CONTROLLER AND I DONT KNOW HOW TO SET UP THE BOOST
THE CAR HAS PORTED HEADS, TE60 TURBO, 3000 STALL CONVERTER, 4" MAF PIPE, 3.5" LS1 MAF WITH TRANSLATOR,PRECISION PORTED PLENUM, WALBORO FUEL PUMP, EVERYTHING ELSE IS PRETTY MUCH STOCK. THE CAR IS AN 85 AND I CONVERTED THE ENGINE TO INTERCOOLED TYPE
