Where does the harness go to from the ECM to where?Replace the entire harness.
X2Replace the entire harness.
Look for a shorted relay? Injector?
This would be an interesting one to troubleshoot, but very hard to do through a keyboard.....
I would probably open up the ecm and see if I could figure out what circuit smoked and go from there.
i found the transistor it smoked and its the same one on both ecms.. how do i find what it goes to? its on the bottom board kinda in the middle, there is another one close to it and some numbers on the board around it with 103Look for a shorted relay? Injector?
You most likely have a relay, solenoid or injector that is drawing too much current. Here is the way we test these and identify the culprit:
Thanks a lot Dave, your very helpful
1. Disconnect and remove the ECM
2. Using the wiring diagrams identify every pin on the ECM harness that controls an injector, solenoid or relay
3. Configure a DVOM to measure current. Ground the negative lead of the meter.
4. With the key in the run position, one at a time, ground each of the pins you identified in step 2. This will cause the relay, solenoid or injector to turn on. (you are acting like the ECM)
5. Write down the results. Look for the circuit that pulls too much current. Also OBSERVE that the item being controlled TURNED ON! A circuit that doesn't work is probably the culprit.
*The one exception to this procedure is the Fuel pump relay. The ECM uses a High Side Driver to turn on the fuel pump relay. It sends out 12v to turn on the relay instead of providing a ground. To test this circuit/relay, move your grounded meter lead to 12V+
From memory here are the relays and solenoids:
AC relay
Cooling Fans
Boost control solenoid
Evap canister solenoid
ERVR (EGR) solenoid
all six injectors
*Fuel pump relay
I've used this procedure to fix cars that blow multiple ECMs.....it works.
Looking at the original post, It wasn't clear how quick the ECM was damaged.
Remember, the ECM supplies ground to turn most things on (fuel pump is the exception). So if there is a short in a controlled circuit, it has to be a short to power to hurt the ECM.
I've repaired vehicles where a solenoid winding went bad (low resistance) which causes the ECM to sink too much current to ground. This doesn't happen too often, but it will make you pull your hair out trying to find the problem. Just thought I'd share what I've learned.
Replaced fuel pump transistor in ECM , have power to fp relay harness when key is turned on for 2 seconds still won't crank unless I jump b and d terminals out then it cranks, that is the only way to get the fuel pump to run,also bought a relay from autozone.To fry that quick it must be a dead short.
Check the plug for the oil sender.
