E85 users: post your a/f ratio, boost, timing, power level
KevinB
I thought this might be a good thread for people out there trying to get the most out of their e85 tune.
I will start:
3650 lb car w/ driver
131.5 trap speed
11.2 a/f
22 degrees of timing
25 creeping to 26 lbs of boost
6768 turbo, 234" engine
th200 4r trans
2 walbro 307's w/relief pushed in
160# injectors
58% duty cycle
stock fuel rail
-10 feed
stock feed line used as return
No signs of detonation on pump grade e85 that tested at 86% according to my test tube tester.
Afr for gas and e85 are not the same. and if you do get lets say e70 it will be richer than e85. so thats why you should aways tune in lamda. same for all fuels.
You mean lambda? The a/f I posted is the gas scale, which is what my ecu converts the lambda reading into. Its an older system that can not be changed to show a scale for e85. I use the gas scale because it seems to be the universal scale everyone seems to use on the internet. 1.0 lambda is stoich no matter what fuel you run. So, if I have e70, e85, c16 or whatever in the car it will have the same lambda number from what I understand. The a/f ratio is just a converted number from the lambda number. What's the difference then if I say im running 11.2 on the gas scale, 7.1 on the e85 scale or .82 lambda? Those numbers may not all equal each other, I just was using it as an example.
My old setup
104 1/8 mile trap speed
12.8 a/f
21 degrees timing
23 psi
72 trim turbo , .30 over
Th350 trans manual valve body
1 walbro 340 intank hot wired and 1 old style Bosch inline
84lb injectors
Stock fuel rail
Stock lines
No knock ; )
87 GN
10.2 AF/R (1st gear is leaner)
32+GPH Methanol
25psi
25/23 Timing TT Chip
TA49
80lbs
Bosch 044 (killed a Denso in under 1500 miles on E85)
-8 Feed
Champion Rails
Magnafuel 25 Micron Filter
.75 Lambda
21 deg timing
22 boost
670 rwhp mustang dyno
160 lb injector
weldon 2035
-10 feed
-6 return
85% dc
fuel between E80-E85
Big Stuff 3 W/flex fuel sensor option
EGT 1550 all cylinders:eek:
Mod should make this thread a sticky!!! Everyone can keep posting updates as they work out the tunes and track times!!
.75 Lambda
21 deg timing
22 boost
160 lb injector
weldon 2035
-10 feed
-6 return
85% dc
Nice numbers!
10.3 a/f (gonna lean it out when I get to the track)
23 degrees of timing
26 lbs of boost
precision 67mm GTQ turbo, 109 block
magnafuel external pump
120# injectors
83: duty cycle
stock fuel rail(gonna be sawed off and adapted for bigger fitting soon)
-10 feed
0 knock even when I had creep up towards 30.
Stock modified computer with extender pro chip
Track times coming in about a month and a half (after suspension is in place)
My first post although i am not a Turbo Buick owner. It was tuned by Otto. E85 1986 Mustang.
I love to read this section of the forum.
FAST XFI
7.5 A/F=11.2-11.3=.77 Lambda
26 deg timing
18lbs of boost
ID 1000 @100 DC :mad:
PT78GTS
347cu SBF
E75 fall blend
790hp,698tq
86 regal
LS2 V8
88mm t4 h cover
21 deg timing
17 boost
.75 lambda
750 rwhp Mustang Dyno "the real deal"
E80-E85
Big Stuff 3 COP, Flex Fuel
120 lb inj. 95% dc
weldon 2035
dual -8 feed
i like how this thread is going, very helpful for others for there setups...
Sup hellaSlowPokes, what I ran at palm beach a couple weekends ago. 1/4 mile
143 1/4 mile trap speed, 23 degrees timing, TE61 turbo, 21 psi, 12.6 air fuel, .30 over, turbo 350 tranny, walbro and bosch pumps, 96# injectors, stock fuel rail, stock lines...STOCK EVERYTHING! No knock whatsoever:):)
Special thanks to my tuner and builder : GABBY ROJAS....you rock my block!
Very funny buddy, so gabby did your motor with my same parts huh? And you went 143 mph with a te61... Your full of crap , I actually have videos of my car with that setup your mocking . Lets meet at palm beach at lock up something tough guy.
Yeah 143 in a full weight Buick v6 with one 61? Where's the bs flag or where's the rest of the story?
Hahaha who says it's full weight? The things you guys talk about and don't know a damn thing about. Btw, your numbers are PARKED
Yeah you must be at 2000lbs.
Is this a single te61? Is it a 86-87 turbo Buick? Tell us what you have. If its a 3300lb + regal with a buick v6 with all the above I call bs. Te61 on 21 psi?
Kevin come on dude, you can't be serous believing or trying get a true story from this troll, the guy only has 2 posts and pretty much copy and paste's my build and says he knows Gab, he's a jealous prick that has nothing else better to do other than talk crap cuz his cars slow, that is even if he has a turbo Buick.
I smelled troll. The internet is full of dbags like this lol
time for the e85 mod to get in here with his ban hammer , 3 posts and talking like crap /threadjacking a productive thread - likely a vtec owner lol....
hey hey lol I daily drive a 2011 civic si, theres not a day that goes past that I dont hit vtec and rev to 8,600 rpms, but I agree with you probly a honda owner or maybe one of those loser srt4 neon kids.
