I am in the midst of cobbling back together a later SMC kit (that I believe is non-progressive) with the factory coolant resevior bottle.
The pump was pooched and leaking from the body so I tossed it. I decided to run an in line Bosch pump that I had laying around that specs out like so:
I can confirm that it does in fact operate at 72psi @ 12V; this was through a .025" nitrous pill. I didn't take the time to measure the flow... I'll take the pump's word for it.
But, is this enough pressure/flow for meth injection?
Arguably it is the same pressure as my car's fuel system sees under boost (43.5 base + 28-30psi @ 1:1 compensation). If not, I'll just run it to the back of a nitrous fogger with some E85 and run a wet 50-shot out of the hole. LOL.
Thoughts?
Bosch 0 580 254 984 Inline Fuel Pump
Bosch 984 fuel pumps mount inline (out side of your gas tank),
most commonly rear center under your car or truck.
Each Bosch 0-580-254-984 fuel pump provides 165 LPH of flow and operate at 72 PSI.
Bosch 984 Fuel Pump Specs:
Bosch Part Number: 0580254984
Minimum Current: 12 Volts
Operating Pressure: 72 PSI (5 Bar)
Minimum Flow @ Outlet: 43.6 GPH (165 LPH)
Fuel Pump Location: In-Line
Fuel Pump Connections:
Inlet: 12mm (3/8") x 1.5
Outlet: M12 x 1.5
Electrical: Positive M4 / Negative M5
Thoughts?
