Tore down the trans and found several questionable items; installed check ball into feed orifice of 1-2 accumulator, ball not flush with housing possibly causing leakage in this area. I noticed a small cavity in the 1-2 housing that connects 2 spacer plate holes; one feeds the Lo/reverse clutch housing? Another item, the lower solid Teflon seal on the forward drum/shaft was slightly marred during assembly; definitely leaking in this area. I replaced the Lo/reverse clutch housing that I'd drilled a .060 relief into the the edge; not sure if this caused anything, but...? Trans reassembled with same clutch packs, seals etc., pressures are where they need to be; no delay in reverse and very firm shifts. The 2-3 shift feels as if it is binding/dragging? May need to enlarge one hole in spacer plate(which I also replaced). Very happy with results and StageRight Transbrake operation. Thanks for all the responses, John.
