I'm about to install a camshaft in a motor I'm rebuilding and although this might be a stupid question, I'd like to know if degreeing it is really necessary.
I've replaced camshafts in several different motors over the years and have always just lined up the dots on the timing gears and have never had a problem as a result.
If it matters any, here are all the cam specs that I have for it:
Any thoughts?
Thanks,
Christopher
- 255 duration intake
- 260 exhaust
- @ 50 thousands 205 intake 210 exhaust
- lift - 456 intake, 470 exhaust (with 1.6 rocker)
- 285 intake 294 exhaust (lift at cam)
- LSA - 110
- 4 degree advance
- install straight up intake certerline 106 degrees
- hydraulic camshaft
- standard hydraulic lifter
- standard spring 120-130 springs
Any thoughts?
Thanks,
Christopher
