I have a SEFI FAST with WBO2. I recently installed a KB 2.8 twin screw supercharger that I plan to feed with my twin turbos once the stroked motor I have is broken in. BTW, it's a 4.6 stroked to a 302 with Crower Blower cams and 8.3:1 compression and an intercooler (air to water exchanger). I had the turbos tuned pretty good but this seems way different especially in the lower RPMS which makes sense... Anyhow, when I'm taking off from a dead stop uphill especially, it leans way out and I have the VE numbers at similar values in the lower RPM cells (same boost levels) as the higher RPM levels when it's under load when not from a dead stop. Wondering if I should add AE vs MAP or TPS to compensate or should I give it the higher numbers in the lower VE cells as it seems to be wanting? Also, with this setup I have a hard time finding a good idle when I had it nailed with the turbos, but I think I can figure that out, but I would appreciate any idle tuning tips. It's been over a year since I've done any real figuring out on the FAST but I'm on it now...
Thanks for any advice. Turbo Buick gave me all I knew before much more than any Ford site. You guys rock...
Spud
Spud
