I'm trying to tune the chip to match my car and I could use so help from anyone with experience doing a similar thing. I started with the idle and have that nailed. Smooth as glass!
Next I want to get the BLMs in-line during normal driving. Right now, most indicate lean and 1 or 2 indicate rich. Here's where I am:
I set the Injector Constant for the injectors I'm using (ie, 30lb green-stripe = hex 43). This number matches the flow rate at 45lbs psi (30 lbs/hr). Now here's the dilemma, if my BLMs say the mixture is lean, do I change the MAF tables to report less air or do I change the Inj Constant to add more fuel?
I'm leaning toward changing the MAF tables because they problably should be "tweaked" anyway to reflect K&N filter, solid MAF pipe, 1 screen removed, etc. I just don't know a scientific way to go about it, and I'm tired of guessing. Any help would be appreciated.
