car will not start
Pat Adkins
Had the car running & it just stalled. battery had been low so threw the charger back on it & still wouldn't start. replaced battery no start just turns over,shot some starter fluid in still only just spins & doese not appear to have spark.took control module & had it tested & tested good. coil pack has some weird readings on ohms. reads 11.5 ,11.5, & 224.2. then same test was 0,0, & 12.:confused:
any suggestions?
If you have another coil layin around you could try it out. However I would lean toward the crank sensor. Check to see if you are acutally getting spark. If no spark I'd start inspecting the crank sensor.
