- Feb 18, 2006
Readings were at idle.
Then your not getting a map signal. A mp of 98.1 indicates atmospheric pressure. Like the motor is shut off. Should be in the 40's at idle. Check the vacuum line to the map with the motor running. Make sure your getting good vacuum.
The Tpro needs to see manifold pressure and rpm to run the car in speed density.
