Readings were at idle, chip is burned at 850, but i see 830-925 ish due to bad idle and a/f was at 12to1ish if i put it back into closed loop and a/f is at 14.7ish it idles like it's on the verge of death if it idles at all. Brian, no maf, set to speed density. idle is terrible, cruise is not as smooth as I'd like sometimes I have a low cruise rpm miss (1850-2350ish), half throttle is very good, and wot feels mechanically fine, but I have noticed a loss of power. If I rev it in park and try to hold a certain rpm(like 3000) for example, it revs smoothly, holds momentarily, starts to stumble and drops a couple hundred rpms and then holds with a noticeable miss...
