It's pretty much manditory to port the wastegate hole on any P-trim turbine wheel equipped turbo, in order to get the boost levels below 20 and under control. IE: No boost creep.
Also, when running a HD wastegate actuator, you will be lucky if you can get the boost down to 18psi. The as casted hole on a PTE turbine housing should be around .900". Typically you would port this hole out to around 1.25" or just smaller than the diameter of your puck on your downpipe. And the last most important thing is to make sure, make double dang sure, that you have a nice landing mark on your turbine housing, before you start porting the turbine housing. (Landing mark typically shows itself up in the form of carbon / soot marks.) With the puck locations on all the downpipes varying by as much as 1/2" in some instances, you can see why this is such a crutial thing to get right. If you port the wastegate hole too far off to one side of the hole or another, you could actually create a gap. This would lead to very, very slow spool up and no boost control.
When we ported my new THB3-76 housing, I ran it for a week with the hole unported, just long enough to get a nice carbon trace. Then, removed the turbine housing, traced the hole with an egravers pen and circle template that was just smaller then the OD of the puck on my TH downpipe, leaving somewhere around 1/16th of an inch for the puck to seal on, then went to grinding. Don't forget to blend the ported area smooth for better flow.
Now, with a Heavy Duty actuator, I can turn the boost all the way down to 18psi. I've run up to 28psi so far, but it killed my tranny last fall.
Hope this helps.
Patrick
