silver/black
- Mar 28, 2007
can you install roller without having head work if lift is stock lift or .... for someone that may want to upgrade to roller without breaking stock head seal
what has to be done to the heads for a big lift roller?You could do it. Just need low lobe lift to keep valve lift low enough as pace car mentioned.
if your heads are stock the 212/212 (.504 lift with 1.55) is not a drop in part
69-300-8
read note 2 at bottom
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=47&sb=2
the exhaust guide needs to be cut down and if you install a seal you need to change the stock exhaust valve for one without the oil groove otherwise the groove will destroy the seal
I see.The reason for changing would be reliability.
