I have the melling roller tip spring button ,cb100 I think, with a factory cam and timing cover. When I put the timing cover on the engine the spring tension is strong. The cover starts on the dowels but I have to push it down the last 1/2-3/8 inch and hand tighten the bolts to hold it down. I have to chalk my engine stand wheels to stop it from moving when I do this. This doesn't seem right. Like it will put to much pressure on the cam into the back of the block. I put the timing cover on without the cam button and it fit fine. I also tried a different cover with the original cam button and had the same problem of having to push it down. Both cam buttons stick out of the cam 3/4 of a inch. Any one run into this before? Seems like the springs should be weaker.
