Wastegate hole on turbo must not be completely covered by the puck in the downpipe.
If the problem is your wastegate hole on your turbo is too large for your puck I have an RJC Block off Plate that might work, if that's the problem. http://www.turbobuick.com/forums/threads/rjc-down-pipe-block-off-plate.397891/The fact you just installed the turbo and now have the have the problem means the puck is probably not sealing...Are you using a different actuator with this new turbo??
