Blocks, Heads, Turbo, IGN, MSD!!!
Kid Turbine
Well car didn't sell so its Buick part sell now to fund the LS2!!!
stock 109 block $300
stock gm heads $150
stock turbo crank $150
stock turbo rods $120
stock valve covers $40
stock front cover $60
stock oil pan $20
Or can be bought complete for $750 already on crate for shipping also!!!
MSD DIS-4 with interface $500
Accel DFI6 ecm and adapter harness $300
(2) stock incoolers $75 each
(2) gn stock turbos $150 together
some misc brackets ?
Okay now for the built engine setup!!!
4.1 non stage block 257 c.i. motor (torqueplate bored and linehoned) $450
Jack Cotton CPT-61 Turbo $750
stock manifold rebraced and welded $100
custom turbo filtering system $100
Sealed power Hyper pistons (4.005") 8.7:1 comp. $150
Reconditioned 2 dot rods $200
Reconditioned 10/10 Turbo crank $200
Upgraded GN Heads with LT1 springs $175
Felpro 1000 head gaskets (free with heads)
MSD 50lb injectors $300
Stock balancer $40
Stock flywheel $40
Stock oil pan $20
Stock coil, wires and module (new) $100
Stock upper and lower intake with Phelum Power plate and fuel rails and ing. bracket and throttle body $400
Comp Cams 212/212 camshaft and lifters $100
stock ecm with Turbo Tweak chip for build $150
Front mounted intercooler $200
in car now running but before part out big items have to sell first or buy complete for $2500
If buy either complete engine I will work with you also!!!!
ill take the balancer and sending pm
Here is the post / pm list so far:
bison - balancer (1)
joe schindler - intercooler (1)
mikestertwo - stock turbos (1)
83 intercooled - cam/lifters (1)
m233roller - 109 oil pan (1)
bison - 109 shortblock (1)
wickedtt - complete 109 engine / complete 4.1 engine (1/1)
TurboTJT - wires/coil/module (1) custom filter system (1) intercooler (2)
daves87gn - wires/coil/module (2)
GNTurboTommy - 109 oil pan (2)
NorEaster - stock turbos (2)
gatering pictures, sending them out to emails, and awaiting decision on which motor also
Send you a PM. Put me in line for the stock oil pan. I assume it is for 3.8L.
Raist103 - manifolds (1) intercooler (3)
MCH86GN - 109 oil pan (3)
49-blues - 4.1 block (1)
here are pics of the 4.1 block which is in the car now!!!
heres pics of the 109 3.8 removed fromt the car except intake system, balancer, and flywheel
pics of the intercooler and piping
I am very interested in your 4.1 & I live in Alabama... call me after 6pm 256-738-0471, Thanks, Tyler
4.1 shortblock, longblock, or complete setup just let me know I will call after 6pm if not call me pm'ing number now!!
At the current time I have two guys and I am awaiting their decision on the complete 4.1 setup and one guy for the 3.8 shortblock. But will update soon as possible!!! Intercooler and turbo available along with stock set of heads.
