I am doing a rebuild on my '86 GN. Someone was into it before me, and made some mistakes which led to me having to build it. I bought the car as a non running basket case with supposedly only a bad turbo. I got it running and put a kit in the turbo, abd discovered the motor was knocking.
I pulled the pan and found one spun rod bearing, and after pulling the engine all the main bearings were in foul shape. The PO had no clearance in the oil pump and it ran metal through the motor and killed the bearings.
They also had installed a 268 comp cam. It sounds cool, but it has a flat spot on tip in, and needs a looser converter, and probably a bigger turbo, and bla bla bla. I just want a stock cruiser with the street manners GM intended. If i want to go fast I will drive my Malibu with a 91mm sbc.
Which manufacturer has the best stock cam for my 3.8?
