challengermike
- Nov 14, 2005
My scanmaster shows my battery volts to be about .5 to 1 or more volts at times less than what the battery is.I have checked it at the alt and battery and they seem to be .1 to .2 volts with in each other.Is this something i should be worried about?I thought the alt was going bad because at night with the cooling fan running and the lights on it was reading 12.5 down to 11.9 on the scanmaster,but the alt and the battery never showed less than 13.9
Now i dont know if this is related or not but ever since i bought the car and put it together the o2 readings have never been right at wot.The most i have seen is 656.And i know its wrong because if i richen the fuel up threw the chip it will run so rich at wot it blow alot of black smoke(yet no increase in the o2 readings(656)
Do you think that i should worry about the scanmaster voltage
