Boostian
- Jul 8, 2013
I recently purchased some parts from a member that included a Turbonetics Raptor BOV. I have everything installed and hooked up. Here's my issue:
It doesn't let off extra boost in a linear fashion. I get an initial expel at the onset of vacuum then I get compressor surge like usual. After adjusting the set screw out as far as possible and doing research I've come up with the following conclusions:
Spring is too heavy? Although I can't seem to find springs for this brand.
My vacuum source is too far away? My line is run from behind the plenum, teed off the vacuum line the MAP sensor runs off of.
Wall diameter of my vacuum hose is too thin? This I'm not sure about, was just a hunch.
So, can anyone running this brand or any other provide some insight into this?
