i bought a car that had a engine and tranny built by russ merritt and i have a whining noise in the tranny.engine is not pulling over 4500rpm and now a headgasket is leaking. the car has not been over 18# of boost and has methanol.i bought the car from a guy about 60 years old and i was told there was between 1000-2000 miles of all of it. and it had apparently another motor built that russ built and blew up while he was tuning for the methanol kit he installed. i am not happy because the only reason i bought the car was russ was suppose to have a good reputation and the main reason i bought the car was for the motor & tranny.i did not want to buy a project car i had enough of them already. form your own opinions but i know i am not happy :frown:
Russ did all that work well over a year if not 2 years ago.
You are not hte guy he did the work for.
So you think he should do something for a second owner 2 years after the work was done?
i know i am not the guy he did work for ! buti was told there was between 1000-2000 miles on everything and EVERYTHING was spotless so i believe it.and russ was suppose to have a great reputation that's why i bought this car.
work was done dec 06 jan 07 feb 07 about 14 months before i bought the car.
hey that's fine if doesn't want to do anything because i did not buy it from him directly.
there was $2500 in the tranny including parts ,labor & convertor.
in the engine there was another $5500 worth of reciepts for labor and parts.
and there were several other parts like turbo,injectors ,supposedly ported heads and intake that i don't have reciepts for.
all i am saying with these many thousands of dollars worth of parts and super low mileage on everything i don't think things should be breaking this soon.
Grumpy, Do you rebuild trannys? I want to go 10s but 11s are the immediate goal. Signature below is out dated. The Transmission is Bruces killer street but is 7 years old.
Russ is it true your done working on Buick? I was told you moved on to bigger and better things.
When is Buick day? I'm getting married on the 6 of sept and will be in CA until the 20.
