KEVINS said:Super Glue..
ks
I use zip ties as well.
Try to find one of these for your tool box.View attachment 170292
Panduit GTS
turbo nasty said:Zip ties here as well. Push locs arent in my budget as of late but they will be the eventual fix for me.
1KWIKSIX said:In addition to the hair spray that I use (for the car...not me, I don't have enough hair left to worry about) LOL, I use Stainless Steel Safety Tie Wire & install it with Safety Wire Pliers. Never had a line blow off yet!
dave
I also prefer this to zip ties. Only down side is drawing blood if you are not careful when working under the hood...
genius!Don't use dikes to cut the remainder off. An electrician showed me a trick: If you take a pair of regular pliers, grab close to the "buckle" part and twist off, it will stretch the tie and when it snaps the end goes back inside the buckle. No more razor sharp edge.
