How does the isac contol boost? Is it like the ams500 and 1000 where u has silenoids? I went to the website doesn't say much on how it actually works and very few pics
Ive noticed a lot of guys are running knock sensors and a/f ratio monitors is there anyone who makes an alky kit that would take input from these two sorces and add alky as the engine needs it automatically? Is it even possible?
thanks
The problem with this is false knock. If you get false knock you flood the engine.
Second problem is is alcohol is used for knock suppression not air fuel trimming. You use gasoline to tune the engine and alcohol to stop the knock. Realize that 15-20% of your fueling is alcohol, the other 80-85% is gasoline. So the gasoline is whats controlled. There are chips and computers that will correct AF under WOT. The XFI from FAST is an example.
Once you have a car dialed in, it doesnt need more alcohol. Meaning there is no reason to increase its volume given a certain level of boost. My kit is set to deliver more than is required right out the box, you can then trim it down as you see fit. In the end its all about tuning. There is no automatic anything as all tuning requires human input
I wont get into swinging on auto corrections. Which is the main reason some dont use it. Example engine misfires.. cuases a lean condition.. computer starts to open injectors to cure lean condition(misfire).. all of a sudden now its too rich... so computer starts to pull out fuel... then its too lean.. and back and forth until the engine settles. Perfect example of this is using a 2step with the correction "on". You'll go nuts tuning it.
Slowest part of any system is the pump. As there is a time lag to develop and reduce pressure/volume. Only way around the time lag is to use fuel injectors above the ports on the runners. I wont get into the costs associated with this. At that point a C16 switch fuel system makes more sense.
I'm trying to understand this, so are you saying that wideband tracking ex: powerlogger and TTchip 6.0 makes tuning harder?
All this computer stuff is so complicated and gives me a headache lol can't some one just invent a computer you plug in and you don't have to tune? Just take the input from the sensors and automatically adjust for optimum a/f ratio and 0 knock? It can't be that hard I mean I'm posting this from my phone while I'm on a call and downloading stolen music!
The factory computers pull timing as it senses knock why can't you change that to add alky as it picks up knock? I'm kinda new here can someone explain what false knock is and what causes it?
Can you imaging two different systems trying to correct at the same time?
Understand a wideband has a lag built based on distance between it and the engine. So when it starts going lean, the computer starts to increase fuel.. it may have only needed 3% but it goes 5,10,15% until the target is reached.. now it goes richer.. and starts to pull fuel.. back and forth like a pendulum.. eventually settling. Anyone who has ever tuned using correction will be subject to this.
Now imagine two different systems fighting each other. Its a mess. datalog pressure.. if its steady, then use fuel(chip,computer,etc) to make the correction. Allow only one Captain on your ship
Wouldn't it be better to use boost as a referance rather than time? Using per pound of boost instead of seconds especially on a street driven type car?
Understandable , so what tool do you recommend tuning with when using your alky and the stock ecm??
