Performed a search on various forms of Front Alignment Specs. Unfortunately many dead links & error messages. Did find the following.
Ridetech
Camber: -.5 to -1.5 [within .3 from side to side]
Caster: 4 to 7 deg. Positive
Toe: 1/16” to 1/8” Toe in
TB Board
The alignment specs you want for a street driven car that's not autocrossed or road raced:
Camber: -0.5 to -1 degree
Caster: as much as you can get
Toe: 1/16" toe in
If you're racing it in parking lots:
Camber: All of it, negative
Caster: install longer UCA mount bolts in the rearward location and get as much as possible, aiming for at least 4 degrees positive, but I'm running six and it's still not enough.
Toe: 0 if running rubber bushings, 1/16" toe out if running poly or delrin.
These are NOT what will be in the computer of a standard alignment rack. But this is what you want.
Anyone have any further information they could add or clarify?
Thanks.
Ridetech
TB Board
Toe: 1/16" toe in
Thanks.
