I was driving the car home from purchasing it, after a lengthy checkout and test drive. About 1 hour and 15minutes of no problems, it started running rough, like it was loaded up. I stopped at the first good spot and smoke was coming from the front of the cat, like burning oil. I had checked all the fluids and they were ok, and no obvious loose wires or missing vacuum hoses. Scanmaster showed no codes.
I babied it home - had to manually keep it in lower gears as it had so little power.
Pulled all 6 plugs, and they all looked fine. Tomorrow I'm going to pull the catoff to check it, and try starting it to see if it runs better.
Scanmaster seems to be working ok as when I pulled the MAF connector off it threw a code 34.
Also, how do you clear codes from the car or Scanmaster, please?
Pulled EGR hose off to see if it would run different - nada. Nosigns of vacuum at the EGR port either.
Any ideas appreciated. I don't know these turbo motors or their electronics at all but have a good EFI background.
Thanks,
Jim
Thanks,
Jim
