1987 Turbo-T for sale
turbov6joe
Signal 1 J-12
I have a VERY VERY nice/clean 84,xxx mile survivor 1987 Buick Turbo-T for sale. I own a small performance shop in Paola, Kansas that specializes in turbo Buicks and have done a lot of very tasteful mods to this sleeper car. I wanted to stick with a stock look but focusing on a driveable high 10 second car which I accomplished with ease. The car is a rare light blue with dark blue interior (1 of ~200 made in 1987) color combo hardtop with p/w, p/l, tilt, cruise, rear defog, posi, concert sound II radio, remote mirror adjustment, power trunk release, aluminum bumper supports and brake drums. The body is rust free and almost lazer straight with incredible OE paint that really shines and looks great! It has the rare black out trim with chrome accents. There are no tears or holes in any of the interior parts and the body is damage free. You really need to see this car to appreciate it. It can be driven anywhere, handles like a charm with the current suspension set-up. All of the parts listed below are new or have been purchsed recently.
Modifications Include:
Numbers matching motor
Reed 208-208 cam and matching lifters
HD rockers with billet girdles
Chrome molly HD push rods
ARP head and main studs
ARP wave lock rod bolts
New bearings throughout
Standard/Standard OE turbo crank
OE turbo pistons (standard bore)
Great compression on all cylinders
Fully ported and polished Champion heads
Champion ported and polished intake (EGR delete)
Precision 70mm upper plenum
RJC power plate for the above plenum
65mm throttle body
MSD 50pph injectors (flow matched)
Precision Turbo 67-76 turbo with .85 a/r exhaust housing
Precision Turbo remote oil filtration
GM Mini starter
200 amp police LT1 alternator
Ground relocation kit
Braided stainless steel turbo oil drain hose
OE wheels with an extra set of 8.5" rear wheels with MT drag radials (275-60)
4 new Firestone Indy 500 street tires (255-60-15 rears and 235-60-15 fronts)
Terry Houston stainless 3" downpipe with 3" single shot stainless exhaust
Alky Control progressive methanol injection system (runs 10's on pump gas!)
Supra 315 lph fuel pump
Recently fully built 200-4R tranny w/ T-Brake and all the good parts
Art Carr 9" non-lock converter (2800 rpm "P" stall)
HR Parts and Stuff rear sway bar kit
No Hop upper control arms
Boxed lower control arms
New rear shocks
New front Koni 3 way adjustable front shocks
15 row 3" inlet stock location stretch intercooler made from 1.5 GNX cores
Aluminum radiator with dual SPAL fans...160* thermostat
Drilled and slotted rotors with carbon-ceramic pads
Stainless steel brake lines
S-10 rear brake cylinders
Convertered to vacume brakes
Headlights converted to 9003 Xenon 80w bulbs
Numerous chrome engine compartment items
PST polly-graphite body bushings
Lower front frame supports
GNX rear seat brace
New HD gel battery
Racetronix fuel pump hotwire kit
B&M stacked plate tranny cooler
B&M oil cooler
A/C delete pulley (includes compressor)
EGR delete plate
Accufab billet fuel pressure regulator
Hurst line lock
EGT gauge with new K type thermocouple
Electronic boost controller with dual boost solenoids
Autometer shift light
Scanmaster 2
Direct Scan with laptop
Autometer oil pressure, boost, tranny temp gauges
Postons audible and visual knock detectors
PLX M-300 wideband O2 sensor and gauge
Stainless test pipe with dump
MSD 8mm race wires
DC Tech powercone with new 9" K&N filter
HR Parts and Stuff polly motor mount
HR Parts and Stuff polly tranny mount
Driveshaft safety loop
Syntheitc fluids in tranny and rear
Valvoline VR1 off-road racing oil in motor
Fresh tune-up and fluids change
This car has run a best of 10.91 and 10.90 @ 121 mph on an easy tune (24 psi and low timing) and runs 11.0's - 11.teens all day long with no problem. It has run a best 60' time of 1.42 and will run 1.5's everyday on a decent track. It typically runs 7.0's in the 1/8 @ 98-99 mph and has run a best of 100 mph in the 1/8 with 6.70's et's....these numbers with a 61-52 turbo!! The new tranny has ~200 street miles on it and has been to the track 1 time since being rebuilt (4 passes). This car was recently driven 500 miles to Bowling Green, KY. for the Buick Nationals (May 2008), averaged 21-23 mpg doing so, ran deep 11's all week and is consitant as hell! I actually won bracket 2 this year with this car running within .02 of my dial and qualified in the #1 position for TAI and B2. The new 6776 turbo will run efficiently at 25-28 psi and should take the car into the mid-10's. Based off of the times posted above I would guess that the motor is making 450-500 hp to the tires with the old turbo. The car weights 3385 pounds without driver (1/2 tank of fuel) and is full OE sheet metal. It has been in Kansas its entire life and has not seen any road salt nor has it ever been a true daily driver. I knew the previous owner who purchased this car in 1990 from the original owner who he knew well...this car is very well cared for and it shows. Please call Joe at 913-244-3829 if interested. Pics available upon request.
$16,500.00. includes everything above plus a few boxes of OE parts, two D5 converters, a set of 8445 heads, ECM's, MAFs, gaskets, late model GM CD radio, and a whole bunch of other parts related to the Turbo Regals that I have accumulated over the last 18 years. This car is done and ready to enjoy, no excuses!! If you want to see a good pic of this car launching on drag radials, check out page 50 of the January 2009 edition of GM High Tech magazine...my claim to fame;)
Here are a few pics.
Couple more
Last few for now.
65mm throttle body
GM Mini starter
New rear shocks
GNX rear seat brace
New HD gel battery
B&M oil cooler
EGR delete plate
Hurst line lock
Scanmaster 2
MSD 8mm race wires
This car has run a best of 10.91 and 10.90 @ 121 mph on an easy tune (24 psi and low timing) and runs 11.0's - 11.teens all day long with no problem. It has run a best 60' time of 1.42 and will run 1.5's everyday on a decent track. It typically runs 7.0's in the 1/8 @ 98-99 mph and has run a best of 100 mph in the 1/8 with 6.70's et's....these numbers with a 61-52 turbo!! The new tranny has ~200 street miles on it and has been to the track 1 time since being rebuilt (4 passes). This car was recently driven 500 miles to Bowling Green, KY. for the Buick Nationals (May 2008), averaged 21-23 mpg doing so, ran deep 11's all week and is consitant as hell! I actually won bracket 2 this year with this car running within .02 of my dial and qualified in the #1 position for TAI and B2. The new 6776 turbo will run efficiently at 25-28 psi and should take the car into the mid-10's. Based off of the times posted above I would guess that the motor is making 450-500 hp to the tires with the old turbo. The car weights 3385 pounds without driver (1/2 tank of fuel) and is full OE sheet metal. It has been in Kansas its entire life and has not seen any road salt nor has it ever been a true daily driver. I knew the previous owner who purchased this car in 1990 from the original owner who he knew well...this car is very well cared for and it shows. Please call Joe at 913-244-3829 if interested. Additional pics available upon request, tell me what you want to see.
Trades considered..new or old, what do you have? (Please no motorcycles, ATV's, or basket cases).
I took the car to the track last Wednesday to try out the 67-76 turbo and did not like it as much as the 61-52. With that being said, the car is being sold with the 61 turbo. The 67 turbo requires too much converter to spool and I prefer to run a tighter N/L converter.
$16k buys it with all the extras included!
Beautiful ride....well worth every penny.. Good luck selling it..
Steve Chambers:eek:
Chages made to ad...please note.
I have a VERY VERY nice/clean 84,xxx mile survivor 1987 Buick Turbo-T for sale. I own a small performance shop in Paola, Kansas that specializes in turbo Buicks and have done a lot of very tasteful mods to this sleeper car. I wanted to stick with a stock look but focusing on a driveable high 10 second car which I accomplished with ease. The car is a rare light blue with dark blue interior (1 of ~200 made in 1987) color combo hardtop with p/w, p/l, tilt, cruise, rear defog, posi, concert sound II radio, remote mirror adjustment, power trunk release, aluminum bumper supports and brake drums. The body is rust free and almost lazer straight with incredible OE paint that really shines and looks great! It has the rare black out trim with chrome accents. There is no fading, tears or holes in any of the interior parts and the body is damage free. You really need to see this car to appreciate it. It can be driven anywhere and handles like a charm. All of the parts listed below are new or have been purchsed recently. Title is clear and car is ready to go.
MODIFICATIONS INCLUDE:
65mm throttle body
Precision Turbo 61-52 turbo with .85 a/r exhaust housing
GM Mini starter
Hurst Quarter Stick shifter (OE shifter included)
New rear shocks
GNX rear seat brace
New HD gel battery
B&M oil cooler
EGR delete plate
Hurst line lock
Scanmaster 2
MSD 8mm race wires
This car has run a best of 10.91 and 10.90 @ 121 mph on an easy tune (24 psi and low timing) and runs 11.0's - 11.teens all day long with no problem. It has run a best 60' time of 1.42 and will run 1.5's everyday on a decent track. It typically runs 7.0's in the 1/8 @ 98-99 mph and has run a best of 100 mph in the 1/8 with 6.70's et's....these numbers with a 61-52 turbo!! The new tranny has 0 street miles or track passes since being rebuilt on 11/14/2008. This car was recently driven 500 miles to Bowling Green, KY. for the Buick Nationals (May 2008), averaged 21-23 mpg doing so, ran deep 11's all week. I actually won bracket 2 this year with this car running within .02 of my dial and qualified in the #1 position for TAI and B2. Based off of the times posted above I would guess that the motor is making 450-500 hp to the tires. The car weights 3385 pounds without driver (1/2 tank of fuel) and is full OE sheet metal. It has been in Kansas its entire life and has not seen any road salt nor has it ever been a true daily driver. I knew the previous owner who purchased this car in 1990 from the original owner who he knew well...this car is very well cared for and it shows. Please call Joe at 913-244-3829 if interested. Pics available upon request.
Price is $16,000.00 which includes everything above plus a few boxes of OE parts, two D5 converters, a set of 8445 heads, ECM's, MAFs, gaskets, late model GM CD radio, some blue interior parts, and a whole bunch of other parts related to the Turbo Regals that I have accumulated over the last 18 years. This car is done and ready to enjoy, no excuses!! If you want to see a good pic of this car launching on drag radials, check out page 50 of the January 2009 edition of GM High Tech magazine...my claim to fame.
Joe,
Car looks good. I should of bought it 3 years ago when I had a chance.
Good luck. TTT
Missed you in Noble this year. Buicks didn't do so good. Oh well maybe next year.
Joe,
Good luck. TTT
Thanks for the complement about the car...and yes you should have bought it then before I had a ton of $$$ tied up in it. I/we wanted I make it down to Noble this year but too many things did not fall into place. Momma is prego again and is due in about 40-45 days...she did not cherish the idea of me being 5+ hours away. Are you thinking about going to BG 2009? What toy do you have now?
The car now has a fresh tranny with 0 miles. I took it out to have my tranny guy make some modifications for me and while in there he replaced any worn parts.
Nice car. Is that Reeds cam a roller or standard lifter cam? It would make a nice gift under tree for someone this Christmas...
Nice car, really only 200 lt blue 87 t's made? I just got this one 2 weeks ago its is just like yours but mine has manual windows no cruise cont. and no pwr seat good luck with the sale if anyone is interested in mine shoot me some offers.
