Well, that run i ran very very rich low 10's AFR .. ran good without any knock. clocked me the 7.3 you see up there But pig Rich, Gabby gave me some food for thought and i did what he said but spun out the hole and got 7;4 @ about 96 mph the 60 was around high 1.8 or 9?! i spun bad.. So i knew we gave it more power. Then i tried one last run did a good burn out to get it stickyy and it did the same thing spun bad so couldnt get a baseline with the leaner AFR. He ran that night too but the track wasn't holding up well it was also freezing cold 50's for Miami is cold! Boost wise the car seems" to be on 1st and 2nd gear @ 26.5-30 psi range it varies?!!? in 3rd gear with tcc lok'd @ 65 it goes up to about 30.2 psi. BUT again i was running very Rich. Gabby is helping me alot with the tune and some advice. After the last run that i spun hard he actually asked me where i had set my tire pressure and it seemed i was running the DR's to to low, which was basically making my tire shrink because of the tiny 8inch rim. On plugs im running r42's @ either 28 or 30 i cant remember off the top of my head?! On the more aggressive tune part i dont think Gabby would want me to say it out loud here, but basically just testing AFR @ levels not posted very often that he has trued and tried i guess would be ok to say? Other than that i mean im trying out some new springs since i have old stocker's and see where i go from there. Im thinking about trying to lock converter in 2nd instead of 3rd seems like i lock the converter and the car really starts to move and im suddenly out behind the 1/8th already. Would like to see it lock in the 1/4 at about 75 mph till the finish line.
