Turbo F-bird
- Jul 18, 2006
Just checking the current thinking on whether to block the 1/2 accumulator off or use the heavier spring most shift kits come with. I've done a lot of searching here and read the CK book but I'm not seeing a common train of thinking on it.
My trans shifts nice and firm, has a shift kit with a functioning accumulator and a 10" 2800 stall converter which is a tight converter not a loose one. The CK book says over 400 HP to block it but I saw posts saying they no longer do that, with a loose converter you should block it to maintain shift feel, with a tight converter you'll break the band lug or other stuff, etc. My engine made just shy of 400 rwhp and should surpass that after I swap out the injectors and bump the boost up so I'm getting paranoid of hurting the band as the power increases. So what's the current thinking these days? I'm a little confused.
