All the discussion of allowing stage blocks in TSM and declining car counts we have to start thinking about opening up the rules to allow more cars in the class if we want to continue this type of racing. I would like to open up the rules to allow more cars and see what happens. If more cars show up to race then we have accomplished something good, if car count stays the same we haven't lost anything. I'd like to have something in place by now so everyone has ~6 months or so to get ready for the TB.com Nats.
Here is the starting point and I want to have constructive comments and open minded discussions around this to increase car counts while keeping the racing close as is was in BG this year. Old TSM records etc would just be frozen and we'd start a new list.
Please keep the comments civil and let's discuss.
Here is what I'm thinking, Keep a majority of the rules from TSM but include the following:
XTSM - Extreme Turbo Street Modified is a class based off of the earlier TSM class. To allow more participation the rules will be opened up to allow more combinations of engines. Now 109, Stage I & II, & aftermarket blocks will be able to race together in heads up class like never before.
2012 RULES
MAIN RULE:*** All rules subject to change due to fairness ***
3250 lbs - Iron Production "8445" casting head / 109 / 71mm
3450 lbs - Aluminum (Champion Style) head / 109 & Series II / 71mm
3650 lbs - Any other block (Stage I & II on/off center, etc) / any style head / 71mm
-100 lbs for 67 3-bolt turbo from any combo
+100 lbs for Alcohol injection
*Safety requirments per track tech
*Factory Stock Appearing External Body must have headlights/tailights (81-87 Regal)
*FSA glass windows
*One 3 bolt turbo up to 71.5mm inducer/103mm exducer in factory stock location (No V-band downpipes)
*No Nitrous Oxide injection
*Iron heads must be production "8445" heads
*Stock suspension/mounting points (no wheelie bars)
*No mini tubs, notched frame ok.
*Any Exhaust: must exit in stock location
*Wastegate must plumb back into downpipe
*Gasoline fuel only (includes E85, Sunoco, VP, etc)
*Alcohol Injection +100 lbs
*70mm Throttle body/cast intake manifold
*Tires - 15" wheel Front must be 3.5" wide footprint. Rear tires up to 29.5" x 10.5"(Slick), 29.5" x 12.5" DOT (ET-Street), or up to 295 series (Drag radial)
*Any GM automatic transmission
*Any GM differential, Dana 60, or Ford 9"
Ultimate Goal
-The 71 turbo would limit the overall power potential to keep class ET close
-The 109 weights would improve 109 longevity
-Stage rules would allow more cars to join in with minimal changes
-Allows for many different combos to be competitive
2012 RULES
*FSA glass windows
Ultimate Goal
