I have just had the 2004r in my 65k 1986 t-type rebuilt.
When driven normal the trans shifts crisp in all gears, down shifts are good too, lock up is normal, everything good right/ Wrong.
Now at WOT, shifts are at 3500 rpm and flare ingagment of the 1-2 and the 3-4!
Here is the components in the trans, rebuilt front pump with 13 vain pump, harden input and drum, clearance on the disks at .005, trany cooler installed, stock D5 converter, fluid 1qt over.
Need input on what is needed to resolve WOT problem with flare.
Before rebuild trans would ripe the tires.
Please respond . Thomas
