norbs said:Ask Dutweiller, he would not lie.
CTX-SLPR said:where would it be coming from Bruce, I could understand it if its robbing igintion power power or like norbs pointed out, getting exhauste ignition. However the idea of having any fuel and air in a mixture capable of lighting off during exhauste stroke is rather low. I'm thinking its stealing amps, though with your setup, dont' see how that would make enough of a difference to take power.
And don't forget that Tornado air thingie either!!turbo2nr said:With magnets and some Slick-50, you can gain that lost HP right back.
Sure can fit, ask Tony Gomes,Although you must use a certain distributor,WHITE T said:It will not fit with factory bracket and AC, you will need to run the Champion AC delete bracket.
HTH
With the alternator relocater piece, there are still a few other things to change. Without the relocater, you have to be quite inventive as Tony G was with his install.norbs said:Will this fit with the factory alt bracket/ ac? What are the options here?
