Very true, the faster you get the less time you have for looking around....PowerLogger time^ This guy
There is a lot of data that flows in and it's kind of hard to watch gauges and drive. Log and look later
I would like to know what you guys are looking at? I have plenty of time to glance at my wideband in third..Where it counts.
I would never tune my car flogging it and then see what kinda damage I did in a log.
Boost, fuel pressure, knock and perhaps an AFR ....I guess you would wanna make sure all is good while making a pass, hence the need for logging the runI would like to know what you guys are looking at? I have plenty of time to glance at my wideband in third..Where it counts.
The only downside is deciding how to get the wire into the engine compartment. One mine, I cut the bigass plug off, routed the wire through a normal sized hole and soldered it back together. (that day was the day I learned my tool was too big to extract the wires from the PLX plug)
Its like listening to people at the local "advance zone" the other day they told someone that you shouldn't build a motor for E85 unless you want to double the amount of fuel you use and change you plugs and oil every 100 miles...I swear it's like there's certain members of this board that thrive on leaving bad information in the archives just in case someone decides to do a search.
Awesome........One of them told me one time that his stock LS1 is faster and I should have bought the gnx cause it came with a twin turbo v8
Sorry earlbrown!!! I had no idea I did that. Must of happened thumbing though my iPad!!! I'm just reading this thread learning. My apologies!
Earl sounds like he knows what he is talking about. I really feel bad!!!!!
