You really have very few choices in the stock door-panels, becuase as you discovered the window motor is in the way. These are the neodymium magnet Focals, not cheap and they really dont produce as much mid-bass punch as I would like. The easiest thing to do, bar none, that would produce the best sound quality would be to use a set of Q-forms and you can put a 5.25 and tweeter in them. You can run a 6x9" woofer in the rear deck and band pass cross it over from say 120-500hz, and use a powered tube or something similar as a sub-woofer in the trunk. Another option would be to build out the door panels using fiberglass, but I would still - as Wendy advises - put the tweeters in the kick panel for stereo imaging.
