My neighbor is a buick tech he has nothing good to say about the new regal his dealer has done 3 motors do to timing chain failures and 6 chain guides that's because the customers cared and bought the car in for a noise:tongue: me being a tech my self and a lot of expieriance with caddys in the past opel also built the motors for the cts which has nothing but chain problems
GM has not learned I guess my neighbor also started to see them with a lot of electrical prob also the bottom line is I love my turbo regal but the new ones don't even come close. I just don't see how gm is still in buisness because there cars are junk!!!!!! The best american car today is a ford GM or chrrysler don't even come close so that's my take on the new regal guys info coming straight from a buick tech with 21 years with buick !!!!!!!!
This is a false satement, the turbo motor in 2011+ Regal (LHU) is derivitive of the LNF motor used on the Solstice/Sky, Cobalt SS/TC and HHR SS except the LHU motor is E85 capable and uses a cam driven vacuum pump. The LHU Ecotec 2.0L turbo is the first direct-injected turbocharged production car capable of running on any blend of gasoline or E85 ethanol.
I use to own a HHR SS previously to buying the Regal Turbo, I was sitting at 370 whp w/ 93 pump gas and 390 whp w/ E30 blend on stock internals, bolt ons and a bolt on BNR 2871GT hybrid turbo. That pretty impressive if you consider the stock power rating is 260 crank hp and I never upgraded any engine internals.
I have never seen one failure posted on any of the Ecotec 2.0 turbo motor due to a timing chain on all the various Ecotec turbo forums I was on, stock or modified.
Here something else for you to maul over, with just a mild 20 psi
tune only on the new Regal turbo, you can bump your power from 201 whp/233 wtq to 262 whp/284 wtq.
There's not to many other cars out there where a tune is going to give you 61 whp / 51 wtq, stock without bolt ons, turbo upgrade or anything.
There is definetly potential with the Ecotec 2.0 turbo, there are LNF cars running around 400-450whp on stock internals, bolt-ons and turbo kit upgrades.
ZZP performance is making over 600 whp on a LNF 2.0 Ecotec turbo engine with rods/pistons and upgrades. They are coming out with there own EFR hybrid turbo that is a true bolt on only turbo for the LNF which means it will bolt on the LHU and have already posted dyno results making over 500 whp with it.
