what is best # for the IAC? i have scangauge and keeps stalling
Yah's 87
daily driver, already set the TPS , and checked vacuum lines. do have delete on the exhaust back pressure valve on drivers side bank. I have a MAF translator and pretty much run close to 128 blm at WOT and idles decently a little rich. thanks for the wisdom, Ronjon
At idle numbers should range between 10-50, depends on how your car likes to run, but any adjustments to IAC, and you will have to check and adjust the TPS to keep it in range. Might take a few tries to accomplish it, when I set mine up, it took 3 adjustments to get it dialed to good #’s that my car liked.
Good luck with getting it set!!!!
Spray the throttle body with cleaner. Remove the iac valve and spray it too. Probably lots of carbon build up.
Please be very careful re-installing the IAC valve. One little cross thread and you will have major problems. But, I'm sure you are already aware of this danger.
