I'm experiencing an extremely rich condition right around redline... this causes a miss (i don't have any rev limiter on the car right now)... the dyno's wideband verifies that the afr is flat until the last 100-200 rpms and then it drops like a brick... anwyay, if you look at my log going down the track you can see that i get to roughly the same rpm and MAP in each gear... however, in first gear its showing an injector duty cycle of 95%, in 2nd gear it only gets to 83%, in third its 90%... the gears with the higher duty cycles were missing more... the only thing that is changing significantly is the air temp (starts at 110 F and gets up to 185 F)... my ATS correction table is all 0's... but what does this mean? i'm in speed density mode... does the computer still have a base correction that its using for air temp? is the ATS table just to trim that? or if the ATS table is all 0's do i not have any ATS correction at all?
here is my log:
http://members.cox.net/blownz/0823p3.log
here is my config file:
http://members.cox.net/blownz/camaro9.gct
anybody have any other ideas as to what would be causing this excessive richness? the dyno guy keeps telling me that if it was just ignition related i'd be seeing LEAN not rich... just put on new valve springs (initially thought it was valve float), new distributor, new coil... plugs and wires seem ok...
thanks!
here is my log:
thanks!
