Hey guys,
Went racing this past weekend at barona 1/8th mile drags here in san diego. I'm hoping to get some help with my tune as a whole. I've attatched my gct along with 5 logs, the 5th run matches the gct as it sits now. As you can see through the progression of the logs I was battling a rich condition with the AFR dropping into the low 9s. I am targeting 10.8 AFR spraying dual nozzle meth. The 5th and final log I was able to get the correction more in line although obviously the tune still needs lots of work.
The car feels great off the line through first gear and then seems to really fall on it's face into second gear, third gear feels almost like the car isn't accelerating at all. I'm logging at 20 fps is it normal for the RPMs to climb so slowly in third gear? Also notice the cars 1/2 shifts at 6500 rpm but the 2/3 is 5500.
I'm utilizing XFI open loop boost control, the car builds over 20 psi in first and second then struggles to hit 19 in third. I need some help in this area especially, I would like to increase boost but don't know how to go about it. Open loop boost control uses wastegate duty cycle vs. tps table specifically for boost level correct?
Really appreciate any opinions, advice, ridicule! Thanks
