Weight savings:
front bumper :
steel reinforcement= 64.5
aluminum reinforcement = 45.8
savings = 18.7 lbs
Bumper Export Braces:
(export brace replaces inner bumper support)
Chrome steel bumper with small steel export brace, no lights installed = 33.5 LBS
Front steel chrome bumper with only the export brace attachments, minus the center piece, no bumperettes, but does have the full length black strip = 26.5 LBS
rear bumper:
steel reinforcement= 69.5
aluminum reinforcement= 45.8
savings = 23.7 lbs
rear brake drums:
steel = 12.5 lbs each
aluminum = 8.0 lbs each
total savings =9 lbs
front sway bar:
stock solid = 30 lbs
f-body hollow = 14.5 lbs
savings = 15.5 lbs
front rotors:
stock = 17.5 lbs
aftermarket (SSBC) = @ 9.5 lbs
total savings = 17 lbs
front calipers:
stock = 6.75 lbs each
aftermarket (SSBC) = @ 3.25 lbs each
total savings = 7 lbs
aluminum radiator support:
http://www.maliburacing.com/aluminum_support.html)
steel = 24
aluminum = 12
savings = 12 lbs
door crash bars:
savings = 38 lbs
sound deadening material underneath and behind rear seat:
savings = 10 lbs
Rims:
stock steel 87 GN rims= 29 lbs each
aluminum = @19 lbs each
Centerline Auto Drags
15x10= 19lbs
15x8= 17lbs
total savings = 40 lbs
Spare tire:
35 lbs
Jack:
15 lbs
Sunroof:
ASC sunroof = 65lbs
newport pop-up sunroof = 30lbs
savings = 35lbs
Exhaust:
flowmaster muffler = 10lbs each
catylytic converter = 5lbs
no cat = 0lbs
no mufflers = 0lbs
total savings = 25lbs
starter:
stock = 18.5 lbs
mini (turbobuicks.com) = 8.5 lbs
savings = 10 lbs
Hood:
stock = 55 lbs
fiberglass = 28 lbs
savings = 27 lbs
Decklid:
stock = 60 lbs
fiberglass = 23 lbs
savings = 37 lbs
a-arms
stock = 9.5lbs each
aftermarket tubular (UB Machine) = 4.5 lbs ea
total savings = 10 lbs
Torque converter
stock D5 = 48lbs
billet 9/11 stall converter = 37lbs
savings = 11lbs
Audio:
12" subwoofer = @ 6lbs each
5 channel amplifier = @ 15lbs
6" speaker = @ 4.5lbs each
A/C:
AC Compressor: 14 1/2 lbs
Core: 6 lbs
Lines: 3 1/2 lbs
Condenser Can: 1 lb
25 lbs total weight loss.
RJC pulleys:
Pulley Weights (All of our pulleys are 100% stock dia.)
Factory Stock Crank Pulley with intercooler fan; 8+lbs.
Factory Stock Crank Pulley no intercooler fan; 6 lbs. 2 oz.
RJC Billet Aluminum Stock Style Crank Pulley no fan. 1 lb. 10 oz.
RJC Billet Aluminum Race Style Crank Pulley Razor 1 lb. 1 oz.
RJC Billet Alum. Race Style Crank Pulley Undersize 15oz.
Factory Stock Steel Water Pump Pulley 1 lb. 8 oz.
Competitors Billet Aluminum Water Pump Pulley 8 oz.
RJC Billet Aluminum Water Pump Pulley "Razor Style" 7oz.
Factory Stock Steel Power Steering Pump Pulley 1 lb. .
RJC Billet Alum. Power Steering Pulley "Razor Style" 7oz.
Factory Stock Steel Idler Pulley 10 oz.
RJC Billet Aluminum Pulley "Razor Style" with bearing 4oz.
Factory Stock Steel Alternator Pulley 7 oz.
Competitors Billet Aluminum Alternator Pulley 3 oz.
RJC Billet Aluminum Alternator Pulley "Razor Style" 2.3oz.
By going to RJC Billet Aluminum Pulleys you can loose over 9 Lbs. of reciprocating weight.
This is equivalent to removing 95 lbs. of non reciprocating weight (claim made by RJC)
